[Qgis-user] qgis server does not return any data from WFS
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Nov 25 04:48:16 PST 2015
Hi Andreas: yes, it's 2.12,
command line works:
QGIS_PROJECT_FILE=/var/www/html/tmp/pokus/vrstva.qgs
QUERY_STRING="SERVICE=WFS&REQUEST=GetFeature&TYPENAME=vrstva"
/var/www/cgi-bin/qgis_mapserv.fcgi
response as expected
Is it possible, that it's related to DISPLAY variable? I've seen it in some
documentation .. if set to :0 or :99 server returns ServerError
Thanks
Jachym
st 25. 11. 2015 v 13:32 odesílatel Andreas Neumann <a.neumann at carto.net>
napsal:
> Since your are now the third person who has the same problem, within the
> couple of days, I suspect that there really is a bug in QGIS server in this
> particular release.
> Is this on 2.12?
> Andreas
> On 25.11.2015 12:29, Jachym Cepicky wrote:
> hi Stefan,
> apache runs as www-data
> the file is accessible via http://localhost/tmp/pokus/vrstva.shp - so I
> assume, it is readable by www-data
> GetMap request as WMS works
> GetFeatureType as WFS does not
> thanks
> Jachym
> st 25. 11. 2015 v 11:38 odesílatel Blumentrath, Stefan <
> Stefan.Blumentrath at nina.no> napsal:
>> Is /var/www/html/tmp/pokus/vrstva.shp readable for user “www-data” (which
>> is the default user for accessing QGIS Server I assume)? Or is that the
>> ‘apache user’ you referred to or did you configure apache to explicitly
>> access through another user than ‘www-data’?
>> Cheers
>> Stefan
>> *From:* Qgis-user [mailto: <qgis-user-bounces at lists.osgeo.org>
>> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jachym Cepicky
>> *Sent:* 25. november 2015 11:28
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* [Qgis-user] qgis server does not return any data from WFS
>> Hi,
>> several days, I'm fighting QGIS server - on lightttpd now on Apache
>> server with *same* result: WFS GetFeatureType request does not return any
>> data.
>> I created project, set all necessary metadat, coordinate systems, made
>> sure data are in readable path etc...
>> I've published the service using qgis_mapserver.fcgi - WMS works
>> (GetCapabilitiers, GetMap, GetFeatureInfo), but WFS works just for
>> GetCapabilitiers, GetFeatureType request returns just the first response
>> element
>> <wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"
>> xmlns:ogc="h .....>
>> and that's all - not even the closing tag. It seems, the server refuses
>> to work in the middle of construction of the response :-(
>> I have
>> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH /var/www/qgis
>> FcgidInitialEnv QGIS_DEBUG 1
>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-server.log
>> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 1
>> but /tmp/qgis-server.log is empty (even created)
>> In the apache error log, only following lines can be found:
>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
>> variable.
>> variable.
>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>> environment variable.
>> variable.
>> ERROR 4: Unable to open /var/www/html/tmp/pokus/vrstva.shp or
>> /var/www/html/tmp/pokus/vrstva.SHP.
>> BUT, accessing the file vrstva.shp from
>> http://localhost/tmp/pokus/vrstva.shp works, apache user can read it
>> and, as I already said: WMS GetMap and GetFeatureInfo works
>> I've tested QGIS mapserver 2.12 and 2.8 on lightttpd as well as apache,
>> with old projects as well as completely new with just one line in shapefile
>> - same result all the time. Ubuntu 15.10 btw.
>> Any hint?
>> Thanks
>> Jachym
> Qgis-user mailing listQgis-user at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151125/6a77bee3/attachment.html>
