[Qgis-user] qgis server does not return any data from WFS
Andreas Neumann a.neumann at carto.net
Wed Nov 25 04:31:56 PST 2015
Since your are now the third person who has the same problem, within the
couple of days, I suspect that there really is a bug in QGIS server in
this particular release.
Is this on 2.12?
Andreas
On 25.11.2015 12:29, Jachym Cepicky wrote:
> hi Stefan,
> apache runs as www-data
> the file is accessible via http://localhost/tmp/pokus/vrstva.shp -  so
> I assume, it is readable by www-data
> GetMap request as WMS works
> GetFeatureType as WFS does not
> thanks
> Jachym
> st 25. 11. 2015 v 11:38 odesílatel Blumentrath, Stefan
> <Stefan.Blumentrath at nina.no <mailto:Stefan.Blumentrath at nina.no>> napsal:
>     Is /var/www/html/tmp/pokus/vrstva.shp readable for user “www-data”
>     (which is the default user for accessing QGIS Server I assume)? Or
>     is that the ‘apache user’ you referred to or did you configure
>     apache to explicitly access through another user than ‘www-data’?
>     Cheers
>     Stefan
>     *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
>     <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Jachym
>     Cepicky
>     *Sent:* 25. november 2015 11:28
>     *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     *Subject:* [Qgis-user] qgis server does not return any data from WFS
>     Hi,
>     several days, I'm fighting QGIS server - on lightttpd now on
>     Apache server with *same* result: WFS GetFeatureType request does
>     not return any data.
>     I created project, set all necessary metadat, coordinate systems,
>     made sure data are in readable path etc...
>     I've published the service using qgis_mapserver.fcgi - WMS works
>     (GetCapabilitiers, GetMap, GetFeatureInfo), but WFS works just for
>     GetCapabilitiers, GetFeatureType request returns just the first
>     response element
>     <wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"
>     xmlns:ogc="h .....>
>     and that's all - not even the closing tag. It seems, the server
>     refuses to work in the middle of construction of the response :-(
>     I have
>     FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH /var/www/qgis
>     FcgidInitialEnv QGIS_DEBUG 1
>     FcgidInitialEnv QGIS_SERVER_LOG_FILE  /tmp/qgis-server.log
>     FcgidInitialEnv QGIS_SERVER_LOG_LEVEL  1
>     but  /tmp/qgis-server.log is empty (even created)
>     In the apache error log, only following lines can be found:
>     Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>     environment variable.
>     Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>     ERROR 4: Unable to open /var/www/html/tmp/pokus/vrstva.shp or
>     /var/www/html/tmp/pokus/vrstva.SHP.
>     BUT, accessing the file vrstva.shp from
>     <http://localhost/tmp/pokus/vrstva.shp> works, apache user can
>     read it and, as I already said: WMS GetMap and GetFeatureInfo works
>     I've tested QGIS mapserver 2.12 and 2.8 on lightttpd as well as
>     apache, with old projects as well as completely new with just one
>     line in shapefile - same result all the time. Ubuntu 15.10 btw.
>     Any hint?
>     Thanks
>     Jachym
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151125/e408b7cb/attachment.html>
