[Qgis-user] QGIS: Print Composer shifts polygon layer in	exported image
    Mark Coletti
    mcoletti at gmail.com
    Fri Apr 29 09:25:35 PDT 2016
On Sun, Sep 6, 2015 at 8:11 AM, Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
wrote:
> Hi,
> when the source of the problem is really the Open Layers Plugin, then
> maybe try the QuickMapServices plugin instead.
Just as a surprise follow-up, thank you for making this suggestion.  I,
too, was having problems with the qgis print composer mangling maps that
had an Open Layers component.  I installed the QuickMapServices plugin, as
you suggested, and re-rendered my layers accordingly.  My problems
immediately went away.  Thank you!
Moreover, as a bonus, the QuickMapServices OpenStreetMap layer now has
properties I can tweak, which Open Layers still lacks.  (In this case, I
needed to dial up transparency, which I still cannot do from within qgis.)
 So not only did using QuickMapServices resolve my problem, but also made
my work flow a little simpler, too.
Cheers,
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160429/2868164d/attachment.html>
