[Qgis-user] QGEP
AVICOMARTIN avicomartin at gmail.com
Fri Aug 5 01:52:52 PDT 2016
Hi Tyler,
You can try to use the Virtual Machine provided (link is in documentation ).
I tested the sample data and get database errors when try to insert
values in spatial_ref_sys table. For solve this I used the Virtual
Machine to do a data backup and restore it in my database.
Tudor Barascu has created another Virtual Machine including qgep and
qwat data samples (qwat i another qgis solution for water management)
and you can get links in qwat documentation
El 04/08/2016 a las 16:14, Tyler Veinot escribió:
> Anyone using QGEP?
> https://qgep.github.io/docs/installation-guide/database-initialization.html
> I am trying to use the backup file to build the database as per the
> directions but I get Exit Code 1. All I can find through other sources
> is Exit Code 1 is an issue with permissions.
> If anyone has tried/used QGEP and has an idea let me know please.
> Thanks;
> Tyler
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160805/c7a69ef7/attachment.html>
