[Qgis-user] can the georeferencer plugin rotate?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Aug 6 19:39:12 PDT 2016
I imagine your are dealing with raster?  You will need to select the method  for georeferencing, then press the button to execute the command.  I can't give more details as I don't have Qgis in front of me.  You will see many examples on YouTube.
Nicolas
On Aug 6, 2016 10:12, "積丹尼 Dan Jacobson [via OSGeo.org]" <ml-node+s1560n5279770h31 at n6.nabble.com> wrote: If I have a triangle ABC on the canvas, and a similar triangle in the
georeferencer plugin window, and I map A to B, B to C, C to A, what must
I do to see the final map rotated?
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/can-the-georeferencer-plugin-rotate-tp5279770.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/can-the-georeferencer-plugin-rotate-tp5279770p5279793.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160806/dc74aa97/attachment.html>
