[Qgis-user] Label buffer rings
Carlos Cerdán sig.upagu at gmail.com
Tue Aug 9 08:42:47 PDT 2016
What about to set coordinates for your labels?. You would can calculate X
and/or Y label coordinates as center coordinates plus radius of buffer plus
some aditional length acording your presentation scale. These values must
be in a field and, on your label menu, you must set Ubication as "Data
defined". Even rotation can be controlled this way.
Good luck
Carlos Cerdán
2016-08-09 9:54 GMT-05:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
> Hi,
> I'm searching for a convenient way to label buffer rings around a central
> point the way I like it.
> The standard layout looks like this in the screenshot.
> https://ibin.co/2qyymNujAt17.jpg
> I found no settings to get:
> - the lables be stacked vertically to the top, instead of the default
> horizontally to the left
> - the labels be positioned on the outer line of the buffer zone. I could
> live with the other numbers in the center of the ring, but the 1000 right
> on top of the center is nonsens.
> Dragging them manually to a position is still possible, but a "standard"
> way of doing this would be preferable.
> Any hints?
> Cheers
> Bernd
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160809/91acdc73/attachment.html>
