[Qgis-user] Label buffer rings
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Tue Aug 9 09:04:57 PDT 2016
Hi Carlos,
thanx for pointing me to this.
My layer already contained a field "distance" with the buffer rings size.
I added x and y fields to the layer, copied the center points x-value with
the Info-tool and filled it in for x, and then copied the y-value and
added the "distance" value to it in the field calculator.
https://ibin.co/2qzJcy2eSDO0.png
https://ibin.co/2qzJu8hn4d9A.jpg
Anyway it would be nicer to somehow just tell QGIS to label into other
directions than left.
And then being able to align labels to their center would make the world
nearly perfect.
Cheers
Bernd
Am 09.08.2016, 17:42 Uhr, schrieb Carlos Cerdán <sig.upagu at gmail.com>:
> What about to set coordinates for your labels?. You would can calculate
> X and/or Y label coordinates as center coordinates plus >radius of
> buffer plus some aditional length acording your presentation scale.
> These values must be in a field and, on your label >menu, you must set
> Ubication as "Data defined". Even rotation can be controlled this way.
> Good luck
> Carlos Cerdán
> 2016-08-09 9:54 GMT-05:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
>> Hi,
>> I'm searching for a convenient way to label buffer rings around a
>> central
>> point the way I like it.
>> The standard layout looks like this in the screenshot.
>> https://ibin.co/2qyymNujAt17.jpg
>> I found no settings to get:
>> - the lables be stacked vertically to the top, instead of the default
>> horizontally to the left
>> - the labels be positioned on the outer line of the buffer zone. I could
>> live with the other numbers in the center of the ring, but the 1000
>> right
>> on top of the center is nonsens.
>> Dragging them manually to a position is still possible, but a
>> "standard" way of doing this would be preferable.
>> Any hints?
>> Cheers
>> Bernd
>> --Bernd Vogelgesang
>> Siedlerstraße 2
>> 91083 Baiersdorf/Igelsdorf
>> Tel: 09133-825374
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160809/6db7e658/attachment.html>
