[Qgis-user] Numpy Version
h hdixon at bigpond.net.au
Tue Aug 9 13:44:17 PDT 2016
On Tue, 9 Aug 2016 07:50:13 -0700 (PDT)
Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> I cannot answer your question directly but u can offer my grain of
> salt.  Generally, the correct version of numpy should be
> Installed with Qgis. However, if you have an other version of Python
> installed on your machine (like Anaconda), the plugins and Qgis could
> look at that if the Linux environment considers that second install
> as the main default Python package.  Make sure this is not an
> environment variable thing. As this is Linux, I have limited
> experience with this problem but I have seen it in Windows. Hope this
> help! Nicolas On Aug 8, 2016 3:34 AM, "h [via OSGeo.org]"
> <ml-node+s1560n5279854h35 at n6.nabble.com> wrote:
Hi Nicolas,
many thanks.  Yes, I think QGis for Windows installs its own Python
stuff.  But my recollection is that on Linux it uses what is on the
system -
Thanks again
> 	Hi,
> I am running 'latest and greatest' opensuse linux, and the
> related packages, including QGIS 2.16.1, on a x64 machine.
> I am having trouble with some plugins (profile tool being the one I
> care about today) but I get the following error quite frequently:
> RuntimeError: module compiled against API version 0xa but this version
> of numpy is 0x9
> I have opened a python shell, and "Print(numpy.__version)"
> gives me 1.8.0.  I believe this is the current version distributed
> with OpenSuse.  I also believe the current version of numpy is 1.11.1.
> Can someone explain what numpy versions of 0xa and 0x9 in the qgis
> error message mean? (hex values of decimal 10 and 9, I know but how
> this relates to my version of 1.8.0 I don't know)
> Should I 'just' install the latest version of numpy from
> http://www.numpy.org/  or are there some 'gotchas' I should
> be careful of...
> With thanks
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> 		If you reply to this email, your message will be
> added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Numpy-Version-tp5279854.html
> 		To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from
> Quantum GIS - User, click here . NAML
> http://osgeo-org.1560.x6.nabble.com/Numpy-Version-tp5279854p5280083.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
