[Qgis-user] SID and some filegeodatabase features not recognized in QGIS 2.14.5
James Wood
jwood911 at gmail.com
Thu Aug 11 19:16:21 PDT 2016
Hey Tyler,
I haven't seen a response on this one yet; do you have a solution? I work a lot with file geodatabases in QGIS. I'm currently running 2.16, but don't remember ever having a problem in 2.14 (Win 7 SP 1 x64).
Can you respond to the following questions for more clarity?
1. What version is the file geodatabase? You can find this on the General tab of the Properties window for the geodatabase itself in ArcCatalog.
2. Specifically what features are not loading? Can you see them at all in the add dialog or they just won't load? Are they simple or complex object classes (i.e., simple linear feature class vs a geometric network)?
I'm not much of a raster guy, so it's best if someone else weighs in on your MrSid/GeoTIFF issue.
Best Regards,
James
Sent from my iPhone
> On Aug 8, 2016, at 07:27, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Hi All;
> I just noticed since moving to the 2.14.4 LTR that some filegeodatabase features and SID geotiff's will not open in QGIS getting a file not recognized error. I tried to install the gdal libraries with OSGeo4W Installer as well as completely uninstalled and reinstalled QGIS/OSGeo4W with LTR 2.14.5 and a full OSGeo4W Install. Still getting the error, has anyone else have this issue? Those running 2.12.x have not reported an issue so I am assuming it is something to do with my install and/or QGIS version.
> Noticed someone on the Stack Exchange website had the same issue and it was resolved by installing the GDAL Libraries and mrsid libraries, which should have been installed when I ran the OSGeo4W installer. Using 64bit windows and 64bit QGIS/OSGeo4W.
> Any help would be appreciated;
> Thanks,
> Tyler
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
