[Qgis-user] How set default as "show all features"
Burghardt.Scholle at stadt.wolfsburg.de Burghardt.Scholle at stadt.wolfsburg.de
Thu Aug 11 22:18:49 PDT 2016
Hi Andrea,
under "Settings -> Options -> Data Sources -> Feature attributes and table -> Attribute table behavior" you can change the default setting to "Show all features".
Hope this helps.
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Andrea Peri
> Gesendet: Donnerstag, 11. August 2016 16:11
> An: qgis-user
> Betreff: [Qgis-user] How set default as "show all features"
> Hi,
> When start qgis is always starting with option "show feature visible on map"
> in attribute windows.
> I know is possible to change it to "show all features".
> But when I close qgis and restart it it return to original setting "show feature
> visible on map".
> The option "show feature visible on map".
> Too much times our users give us some datasets where there is hidden
> wrong records because outside from visibility box.
> These happened because our users forgot to set the "show all features"
> and so dont see the wrong records to delete.
> There is a configure solution to set qgis to start always with option "show all
> features" ?
> Thx.
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
