[Qgis-user] calculating progressive value
Christine
geo.guide at web.de
Sun Aug 14 05:07:15 PDT 2016
Salvatore Oliveto wrote
> Hi, I have a Qgis layer with a table with twno columns X and Y.
> The X column has a set of values, while in the Y column I have to enter,
> using field calculator, for each record the progressive value. Eg : X
> column values: a , b , c , d ; Y column values (to be calculated with the
> field calculator from Y column): a; a + b; a + b + c; a + b + c + d.
Hi Salvatore,
not really sure, if I understood you properly, but you can use a "case when
... then ... else" condition in field calculator. Please adapt the following
pattern to your needs:
CASE
WHEN X = a THEN a
WHEN X = b THEN a+b
WHEN X = c THEN a+b+c
WHEN X = d THEN a+b+c+d
ELSE 'error value'
END
Hope this helps,
regards, Christine
View this message in context: http://osgeo-org.1560.x6.nabble.com/calculating-progressive-value-tp5280693p5280699.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
