[Qgis-user] calculating progressive value
Salvatore Oliveto
salvatore.oliveto at terralab.eu
Sun Aug 14 03:10:06 PDT 2016
Hi, I have a Qgis layer with a table with twno columns X and Y.
The X column has a set of values, while in the Y column I have to enter,
using field calculator, for each record the progressive value. Eg : X
column values: a , b , c , d ; Y column values (to be calculated with the
field calculator from Y column): a; a + b; a + b + c; a + b + c + d.
How can I do this?
thank you
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160814/7f6aec43/attachment.html>
