[Qgis-user] defining a variable width vector style
Robin Paulson robin at bumblepuppy.org
Tue Aug 16 20:43:59 PDT 2016
On 2016-08-15 08:16, Tom Lennon wrote:
> It appears that you can make arrows with tapered shafts.
> The shafts hasve start and end width settings and the heads could be
> set small.
> The shafts can also follow curved lines.
> Haven't tried it yet
yep, that worked. cheers Tom.
unfortunately i realised there's a further problem: my style is more
complicated than a simple line, so it doesn't quite work as i need. i
may have to dive into python. can anyone recommend any good tutorials
for getting started with qgis styles and python?
robin
