[Qgis-user] My text was cutted by Qgis-server
Neumann, Andreas
a.neumann at carto.net
Tue Aug 16 23:41:47 PDT 2016
Hi Zhangkai,
Please be more specific about what your real issue is. Are you using
tiles or a single image WMS? Where exactly are the labels cut? At the
image border or somewhere inside the rendered image?
What label methods are you using? What settings?
Is your server publically available so we can check? Can you share a
small demo showing the issue?
Best, would be to open a bug report at https://hub.qgis.org/ [1]and
upload some project and small sample data set and steps to reproduce.
We need much more information in order to help you.
Andreas
On 2016-08-17 08:33, Paolo Cavallini wrote:
> Il 15/08/2016 03:07, zhangkai.gis ha scritto:
>> Hello all,
>> I published a map(based shp layer) though Qgis-server.I make a layer
>> with point,then I add label to the layer.so I got a text layer in
>> Qgis.But when I publish it through the Qgis-server.I found that some
>> text was cutted and did not shown.Is it the correct way to publish text
>> layer?How to improve it?
> Hi zhangkai,
> pleas euse exactly the same font on the desktop and on the server.
> All the best.
Links:
[1] https://hub.qgis.org/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160817/3d131ef3/attachment.html>
