[Qgis-user] Are there any users working with the Oracle client on Ubuntu?
Neumann, Andreas
a.neumann at carto.net
Wed Aug 17 02:08:23 PDT 2016
Hi Andy,
In Uster I did this for Ubuntu Server - but mainly for automated OGR
conversions - not really for QGIS server. But it should work for QGIS
Server as well.
In Kanton Zug I installed the Oracle client on CentOS, which is of
course rpm based and it worked fine.
Usually you have to set/extend certain environment variables, such as
* PATH
* LD_LIBRARY_PATH
* ORACLE_HOME
* TNS_ADMIN
Let me know, if you need assistance.
Andreas
On 2016-08-17 10:32, Schmid Andreas wrote:
> Hi
> While we're usually working with a PostGIS database, for a specific project we're thinking about connecting from QGIS to an Oracle Database this time. This should basically be possible. However, our QGIS runs on Ubuntu 14.04, and it seems that the Oracle client installation isn't quite straightforward on Ubuntu. The instructions on e.g. https://help.ubuntu.com/community/Oracle%20Instant%20Client suggest to convert RPM packages from Oracle with alien, which I don't feel comfortable about for a production system.
> In order to get a feel if working this way is wise, I'd like to know if there is anybody of you using QGIS with an Oracle client on Ubuntu in a production environment? Do you consider it reasonable? Or would it be crazy to implement such a setup? Does anybody know if there exist any original Ubuntu packages of the Oracle client?
> Thanks for your valuable input.
> Andy
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160817/59d4f27f/attachment.html>
