[Qgis-user] Are there any users working with the Oracle client on Ubuntu?
Schmid Andreas Andreas.Schmid at bd.so.ch
Fri Aug 19 07:21:04 PDT 2016
Thank you, Andreas and Jürgen, for your encouraging replies. I actually already managed to install (and configure) Oracle Client before, but I’m just still uncertain if “manage to install” is enough for later productive use.
Maybe I’m too much concerned, and maybe I’m trying too hard to keep things simple. But compared to a simple “apt-get install postgresql-client“, installing and maintaining the Oracle client on Ubuntu seems like a tremendous effort, if not a hack ;-).
I’ll check again if we have any alternative possibilities (e.g. exporting the data and importing them into PostGIS). If not, we’re at least not the only ones installing Oracle client on Ubuntu. If yes, we’ll gladly avoid it.
Andy
Von: Neumann, Andreas [mailto:a.neumann at carto.net]
Gesendet: Mittwoch, 17. August 2016 11:08
An: Schmid Andreas
Cc: 'qgis-user at lists.osgeo.org'
Betreff: Re: [Qgis-user] Are there any users working with the Oracle client on Ubuntu?
Hi Andy,
In Uster I did this for Ubuntu Server - but mainly for automated OGR conversions - not really for QGIS server. But it should work for QGIS Server as well.
In Kanton Zug I installed the Oracle client on CentOS, which is of course rpm based and it worked fine.
Usually you have to set/extend certain environment variables, such as
  *   PATH
  *   LD_LIBRARY_PATH
  *   ORACLE_HOME
  *   TNS_ADMIN
Let me know, if you need assistance.
Andreas
On 2016-08-17 10:32, Schmid Andreas wrote:
Hi
While we're usually working with a PostGIS database, for a specific project we're thinking about connecting from QGIS to an Oracle Database this time. This should basically be possible. However, our QGIS runs on Ubuntu 14.04, and it seems that the Oracle client installation isn't quite straightforward on Ubuntu. The instructions on e.g. https://help.ubuntu.com/community/Oracle%20Instant%20Client suggest to convert RPM packages from Oracle with alien, which I don't feel comfortable about for a production system.
In order to get a feel if working this way is wise, I'd like to know if there is anybody of you using QGIS with an Oracle client on Ubuntu in a production environment? Do you consider it reasonable? Or would it be crazy to implement such a setup? Does anybody know if there exist any original Ubuntu packages of the Oracle client?
Thanks for your valuable input.
Andy
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160819/6e251d63/attachment.html>
