[Qgis-user] My text was cutted by Qgis-server
zhangkai.gis
zhangkai.gis at 163.com
Thu Aug 18 00:11:33 PDT 2016
Thanks for Andreas, It works.
2016-08-18
zhangkai.gis
Date:2016-08-18 14:51
Subject:Re: Re: [Qgis-user] My text was cutted by Qgis-server
To:"zhangkai.gis"<zhangkai.gis at 163.com>
Cc:"QGIS User List"<Qgis-user at lists.osgeo.org>
Hi zhangkai,
Please do not reply to me privately. Always reply to the mailing list.
From what you describe below, you are doing tiled WMS requests in OpenLayers 2. Switch to single tile WMS mode and you should be fine. It will then behave the same like in QGIS Desktop.
See also http://gis.stackexchange.com/questions/83033/single-tiled-mapserver-wms-to-avoid-labels-and-features-cut-along-tile-borders-a or the OpenLayers 2 WMS documentation: http://dev.openlayers.org/releases/OpenLayers-2.13.1/doc/apidocs/files/OpenLayers/Layer/WMS-js.html
Just use "singleTile: true" and you should be fine.
Andreas
On 2016-08-18 07:25, zhangkai.gis wrote:
Hello Andreas,
Thanks for your reply.I made a map then publish to qgis server.Most settings are default.When I use Qgis desktop as a web client It works perfect.But when I use OpenLayers 2 to display the map My font was cutted.I made a label with point layer.
My server address is http://222.222.218.51:8888/cgi-bin/room/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
Thanks,
zhangkai
Date:2016-08-17 14:41
Subject:Re: [Qgis-user] My text was cutted by Qgis-server
To:"Paolo Cavallini"<cavallini at faunalia.it>
Cc:"qgis-user"<qgis-user at lists.osgeo.org>
Hi Zhangkai,
Please be more specific about what your real issue is. Are you using tiles or a single image WMS? Where exactly are the labels cut? At the image border or somewhere inside the rendered image?
What label methods are you using? What settings?
Is your server publically available so we can check? Can you share a small demo showing the issue?
Best, would be to open a bug report at https://hub.qgis.org/ and upload some project and small sample data set and steps to reproduce.
We need much more information in order to help you.
Andreas
On 2016-08-17 08:33, Paolo Cavallini wrote:
Il 15/08/2016 03:07, zhangkai.gis ha scritto:
Hello all,
I published a map(based shp layer) though Qgis-server.I make a layer
with point,then I add label to the layer.so I got a text layer in
Qgis.But when I publish it through the Qgis-server.I found that some
text was cutted and did not shown.Is it the correct way to publish text
layer?How to improve it?
Hi zhangkai,
pleas euse exactly the same font on the desktop and on the server.
All the best.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160818/29b8c2fd/attachment.html>
