[Qgis-user] Labelling certain contours
Lester Anderson arctica1963 at gmail.com
Thu Aug 18 08:08:43 PDT 2016
I have QGIS 2.10 (the CASE method works there) and 2.12 here at the
moment. 2.12 shows the rule-based labelling but it does not work with
the rule "ELEV" % 1000 = 0 even though it clearly finds all the
elements when it is tested.
Does it work properly in 2.14 and later then? I can try later on at home.
Cheers
