[Qgis-user] Labelling certain contours
Carlos Cerdán sig.upagu at gmail.com
Thu Aug 18 10:09:35 PDT 2016
Hi Lester:
I'm working with 2.16 and rule labels works fine. Before Andreas' advice,
I've been working with expression "case when...". Not more, rules based is
better...
2016-08-18 10:08 GMT-05:00 Lester Anderson <arctica1963 at gmail.com>:
> I have QGIS 2.10 (the CASE method works there) and 2.12 here at the
> moment. 2.12 shows the rule-based labelling but it does not work with
> the rule "ELEV" % 1000 = 0 even though it clearly finds all the
> elements when it is tested.
> Does it work properly in 2.14 and later then? I can try later on at home.
> Cheers
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160818/adc8c2eb/attachment.html>
