[Qgis-user] Problems with adding WFS layers
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Mon Aug 22 06:50:42 PDT 2016
Hi
Not sure if this is a QGIS or Geoserver issue...
I have a WFS provided through Geoserver v2.5 - I have no issues adding layers from the WFS using QGIS v2.14, but in QGIS v2.16 I am encountering some problems with a selection of layers (within a specific Geoserver store).
The store which holds the layers that are not loading has the 'Expose primary keys' option ticked whereas others do not that are loading ok (I need to expose the primary keys), would this cause any problems? Below is the error I am getting when trying to access layers from this store...
2016-08-22T14:44:41 1 Server generated an exception in GetFeature response: java.lang.RuntimeException: Failed to get property: axisLabels
java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry
2016-08-22T14:44:41 1 Download of features for layer planning:tree_preservation_orders failed or partially failed: Server generated an exception in GetFeature response: java.lang.RuntimeException: Failed to get property: axisLabels
java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry. You may attempt reloading the layer with F5
Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160822/f743c981/attachment.html>
