[Qgis-user] Correct data source encoding for labels
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Aug 24 11:44:19 PDT 2016
do you have this issue only with labels or do you have the same issue in
the attribute table (assuming that labels derive from atributes)?
I also have frequent issues with encoding. The only thing that worked for
me (in some cases) was to check "Ignore shapefile encoding declaration"
under Settings/Options/Data Sources/Data source handling.
If you try this, you should maybe restart QGIS and/or at least remove and
re-add the layer in question.
Cheers
Bernd
Am 24.08.2016, 20:23 Uhr, schrieb Luciano La Sala
<lucianolasala at yahoo.com.ar>:
> Hello QGIS users,
> I am using QGIS 2.14.0 Essen. I have a shapefile for which I need to
> display labels. All seems ok except that accents are displayed as a
> question a mark inside a diamond. I understand this is a data source
> encoding issue. Is there a practical way to solve it?
> Thank you.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
