[Qgis-user] Raster Conversion Missing in Mac OSX 2.14.3
Clifford Snow clifford at snowandsnow.us
Fri Aug 26 16:36:41 PDT 2016
Willian,
Your solution worked perfectly which explains what happened. I recently add
MrSid capabilities to GDAL.
Thank you for your help.
On Wed, Aug 24, 2016 at 2:10 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> Maybe your Gdal Tools Settings changed, and QGIS can't find GDAL.  This
> can happen when the major GDAL version changes - it doesn't update the
> paths for you in the Gdal Tools Settings.
> In a clean install, QGIS has default settings that will work.  You can
> either delete ~/Library/Preferences/org.qgis.qgis2.plist, which will zap
> ALL your QGIS preferences, or open the Gdal Tools Settings and delete all
> the Gdal paths, then restart QGIS.
> > On Aug 24, 2016, at 2:51 PM, Clifford Snow <clifford at snowandsnow.us>
> wrote:
> > Agustin,
> > Thanks for the screen shots. Mine is the same except that I'm running
> 1.11.4 version of OGR. There doesn't seem to be any settings option that
> would cause some of the raster options to be missing.
> > I feel like I'm missing something obvious.
> > Thanks for the help. I may just reinstall.
> > @osm_seattle
> > osm_seattle.snowandsnow.us
> > OpenStreetMap: Maps with a human touch
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now
> and always shall be, there is an eternity of time for the accomplishment of
> objects."
> - the wisdom of Tarzan
@osm_seattle
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160826/131acf0e/attachment.html>
