[Qgis-user] Font Markers
Neumann, Andreas
a.neumann at carto.net
Sun Aug 28 23:02:48 PDT 2016
Hi Grant,
Are you talking about different glyphs in a single font or that every
marker resides is in a different font?
Both would be possible using data-defined properties. But it would be
easier to maintain and probably also faster/more efficient if you use
just a single font and just change the glyph.
You use data-defined columns or expressions using this button, which is
next to every property in QGIS styling and labeling:
http://docs.qgis.org/2.14/en/_images/mIconDataDefine.png
Please read in the QGIS manual about the data-defined properties to
understand the concept. See
http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/vector_properties.html#data-defined-labeling
Greetings,
Andreas
On 2016-08-26 16:00, Grant Boxer wrote:
> I have a series of points in one layer that I want to mark with different font markers. Is there a way I can do this by "defining" a font description in a "font number/id" column?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160829/ae84ba86/attachment.html>
