[Qgis-user] Font Markers
Neumann, Andreas a.neumann at carto.net
Mon Aug 29 00:14:47 PDT 2016
Hi Grant,
I assume that all of your symbols are within the same font - correct?
If yes, if you open the font in your operating system font viewer you
will see each symbol and what character it is representing. You can then
use this character either in classified rendereres, rule-based renderers
or in a QGIS expression, e.g. with a CASE statement. You enter the
chosen character in "Layer properties" --> "Labels" --> "Label with".
Please consult the styling chapter of the QGIS manual for more details:
http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/vector_properties.html#style-menu
[1]- it helps you get going.
And: please do not forget to cc the Qgis-user at lists.osgeo.org mailing
list if you correspond with people. Otherwise only you see the responses
and the rest of the world can't read/contribute to the issue.
Greetings,
Andreas
On 2016-08-29 08:50, Grant Boxer wrote:
> Hi Andreas,
> I was wondering if I can use different font symbols in the same point file, defined by the data-defined properties. How do I reference the individual font symbols? For example, if I have a point file that contains bedding data and joint data, can I get QGIS to allocate the appropriate font symbol to each data type (i.e. font symbol "a" for bedding and font symbol "b" for joints)? Is there say an ASCII code?
> I hope that makes sense!
> Cheers Grant
> Grant Boxer
> Consultant Geologist (_FAIG R.P. Geo_)
> Perth, Western Australia
> Email: boxerg at iinet.net.au
> Mobile: 0418 954 059
> Skype: grantboxer
> Website: www.iinet.net.au/~gboxer
> FROM: Neumann, Andreas [mailto:a.neumann at carto.net]
> SENT: Monday, 29 August 2016 2:03 PM
> TO: Grant Boxer
> CC: qgis-user at lists.osgeo.org
> SUBJECT: Re: [Qgis-user] Font Markers
> Hi Grant,
> Are you talking about different glyphs in a single font or that every marker resides is in a different font?
> Both would be possible using data-defined properties. But it would be easier to maintain and probably also faster/more efficient if you use just a single font and just change the glyph.
> You use data-defined columns or expressions using this button, which is next to every property in QGIS styling and labeling: http://docs.qgis.org/2.14/en/_images/mIconDataDefine.png
> Please read in the QGIS manual about the data-defined properties to understand the concept. See http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/vector_properties.html#data-defined-labeling
> Greetings,
> Andreas
> On 2016-08-26 16:00, Grant Boxer wrote:
>> I have a series of points in one layer that I want to mark with different font markers. Is there a way I can do this by "defining" a font description in a "font number/id" column?
>> Grant Boxer
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Links:
[1]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160829/8116eec6/attachment.html>
