[Qgis-user] Font Markers
Neumann, Andreas a.neumann at carto.net
Mon Aug 29 00:16:47 PDT 2016
On 2016-08-29 09:14, Neumann, Andreas wrote:
> Hi Grant,
> I assume that all of your symbols are within the same font - correct?
> If yes, if you open the font in your operating system font viewer you will see each symbol and what character it is representing. You can then use this character either in classified rendereres, rule-based renderers or in a QGIS expression, e.g. with a CASE statement. You enter the chosen character in "Layer properties" --> "Labels" --> "Label with".
or in your case probably you want to use it directly as a marker: "Layer
properties" --> Style --> Marker --> Font Marker --> Chose a character
interactively or use a data-defined expression.
> Please consult the styling chapter of the QGIS manual for more details: http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/vector_properties.html#style-menu [1]- it helps you get going.
> And: please do not forget to cc the Qgis-user at lists.osgeo.org mailing list if you correspond with people. Otherwise only you see the responses and the rest of the world can't read/contribute to the issue.
> Greetings,
> Andreas
> On 2016-08-29 08:50, Grant Boxer wrote:
Links:
[1]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160829/9e5b5e05/attachment.html>
