[Qgis-user] updating printer composer
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Aug 30 13:29:45 PDT 2016
Hi Dave,
yes it's possible. And it is quite easy:
select your map frame in the composer -> select the "Item properties" tab
-> Hit the "Update preview" button
Cheers
Bernd
Am 30.08.2016, 22:07 Uhr, schrieb <dave.potts at pinan.co.uk>:
> Hi List,
> I am having run with the print composer :-(
> If I work on the main qgus window and create a map image the way that I
> want it, then open a print composer and drag an image of the map on to
> the print >compose. It looks rather nice. Then I discover that I have
> left off some vital feature, I go and edit the main map, but the print
> composer ignores the change. I >have to remove the map image from the
> print composer and re add it.
> Is there any way I can just get the composer to reload/refresh the
> image on the composer to match the main image on the qgis window with
> out having to readd >it ?
> Dave.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160830/f2b57b09/attachment.html>
