[Qgis-user] updating printer composer
dave.potts at pinan.co.uk
Tue Aug 30 23:14:19 PDT 2016
Thaks, as with all things Qgis it can be done, but finding out how or where the button is always an interesting challenge.
In this case the Items properties tab is on the right hand side on the main screen, between Composition and Atlas generation, near the command history window.
I was expecting to find it under one of the icons when I first started looking.
Thanks for providing the information
August 30 2016 9:30 PM, "Bernd Vogelgesang" wrote:
Hi Dave,
yes it's possible. And it is quite easy:
select your map frame in the composer -> select the "Item properties" tab -> Hit the "Update preview" button
Cheers
Bernd
Am 30.08.2016, 22:07 Uhr, schrieb :
Hi List,
I am having run with the print composer :-(
If I work on the main qgus window and create a map image the way that I want it, then open a print composer and drag an image of the map on to the print compose. It looks rather nice. Then I discover that I have left off some vital feature, I go and edit the main map, but the print composer ignores the change. I have to remove the map image from the print composer and re add it.
Is there any way I can just get the composer to reload/refresh the image on the composer to match the main image on the qgis window with out having to readd it ?
Dave.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160831/10547835/attachment.html>
