[Qgis-user] updating printer composer
Nyall Dawson nyall.dawson at gmail.com
Wed Aug 31 01:27:15 PDT 2016
On 31 Aug 2016 4:14 PM, <dave.potts at pinan.co.uk> wrote:
> Thaks, as with all things Qgis it can be done, but finding out how or
where the button is always an interesting challenge.
> In this case the Items properties tab is on the right hand side on the
main screen, between Composition and Atlas generation, near the command
history window.
> I was expecting to find it under one of the icons when I first started
looking.
> Thanks for providing the information
The "refresh" button on the toolbar is also a handy shortcut for this.
Nyall
> August 30 2016 9:30 PM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
wrote:
>> Hi Dave,
>> yes it's possible. And it is quite easy:
>> select your map frame in the composer -> select the "Item properties"
tab -> Hit the "Update preview" button
>> Cheers
>> Bernd
>> Am 30.08.2016, 22:07 Uhr, schrieb <dave.potts at pinan.co.uk>:
>>> Hi List,
>>> I am having run with the print composer :-(
>>> If I work on the main qgus window and create a map image the way that I
want it, then open a print composer and drag an image of the map on to the
print compose.  It looks rather nice.  Then I discover that I have left off
some vital feature,  I go and edit the main map, but the print composer
ignores the change.  I have to remove the map image from the print composer
and re add it.
>>> Is there any way I can just get the composer to reload/refresh  the
image on the composer to match the main image on the qgis window with out
having to readd it ?
>>> Dave.
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> 91083 Baiersdorf/Igelsdorf
>> Tel: 09133-825374
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160831/bb97adc0/attachment.html>
