[Qgis-user] HTML rendering in Map Composer
Neumann, Andreas a.neumann at carto.net
Tue Aug 30 22:28:43 PDT 2016
Perhaps you miss a "webkit" related package? Perhaps do a "apt search
webkit" search and see what webkit packages are available. Something
around webkit with qt and python.
I know that some Debian versions removed Webkit and maybe the newer
Ubuntu versions did so as well?
Hope this helps,
Andreas
On 2016-08-30 21:42, SaekBinko wrote:
> Hello Group!
> I have a problem with text field in Map Composer... When I enable HTML
> rendering on some text field, whole text on map becomes invisible.
> I'm using QGIS 2.16.2 on Linux Mint 18 (Ubuntu 16.04),
> Maybe I have to install some libraries? Everything was fine, when I was
> using QGIS 2.16 on Linux Mint 17 (Ubuntu 14.04)...
> Best regards,
> Slawomir
> View this message in context: http://osgeo-org.1560.x6.nabble.com/HTML-rendering-in-Map-Composer-tp5283130.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160831/f9fe87b0/attachment.html>
