[Qgis-user] HTML rendering in Map Composer
Neumann, Andreas a.neumann at carto.net
Tue Aug 30 23:00:04 PDT 2016
Specifically watch out for:
libqt4-webkit
python-webkit
libqtwebkit4
or whatever the packages are called in Ubuntu these days.
Andreas
On 2016-08-31 07:28, Neumann, Andreas wrote:
> Perhaps you miss a "webkit" related package? Perhaps do a "apt search webkit" search and see what webkit packages are available. Something around webkit with qt and python.
> I know that some Debian versions removed Webkit and maybe the newer Ubuntu versions did so as well?
> Hope this helps,
> Andreas
> On 2016-08-30 21:42, SaekBinko wrote:
>> Hello Group!
>> I have a problem with text field in Map Composer... When I enable HTML
>> rendering on some text field, whole text on map becomes invisible.
>> I'm using QGIS 2.16.2 on Linux Mint 18 (Ubuntu 16.04),
>> Maybe I have to install some libraries? Everything was fine, when I was
>> using QGIS 2.16 on Linux Mint 17 (Ubuntu 14.04)...
>> Best regards,
>> Slawomir
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/HTML-rendering-in-Map-Composer-tp5283130.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160831/731bbea0/attachment.html>
