[Qgis-user] HTML rendering in Map Composer
SaekBinko
slawomir.bienias at gmail.com
Wed Aug 31 13:35:47 PDT 2016
Thank You for advice, but it still doesn't work. I installed few packages
with "webkit" in the name, but nothing has changed. I made comparision on my
second machine with Ubuntu 14.04 and there are the same libraries installed,
and HTML rendering works there fine. So maybe other library...
I thought maybe some plugin has bad effect on this problem, but I turned off
all of plugins and HTML rendering still doesn't work.
Thanks for quick response,
Slawomir
View this message in context: http://osgeo-org.1560.x6.nabble.com/HTML-rendering-in-Map-Composer-tp5283130p5283372.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
