[Qgis-user] HTML rendering in Map Composer
kimaidou kimaidou at gmail.com
Wed Aug 31 23:14:05 PDT 2016
It seems it is a problem only for ubuntu and 2.16 (which should be fixed in
master). See some reports:
https://github.com/3liz/QuickOSM/issues/84#issuecomment-239732745
http://osgeo-org.1560.x6.nabble.com/Pyqgis-QgsComposerLabel-issues-with-Html-rendering-state-2-in-QGIS-2-16-tp5280380.html
Cheers
Michaƫl
2016-08-31 22:35 GMT+02:00 SaekBinko <slawomir.bienias at gmail.com>:
> Thank You for advice, but it still doesn't work. I installed few packages
> with "webkit" in the name, but nothing has changed. I made comparision on
> my
> second machine with Ubuntu 14.04 and there are the same libraries
> installed,
> and HTML rendering works there fine. So maybe other library...
> I thought maybe some plugin has bad effect on this problem, but I turned
> off
> all of plugins and HTML rendering still doesn't work.
> Thanks for quick response,
> Slawomir
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/HTML-rendering-in-Map-Composer-tp5283130p5283372.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160901/baf60464/attachment.html>
