[Qgis-user] spatialjoin
Laurent Bourlet laurentbourlet34 at gmail.com
Thu Dec 22 00:26:34 PST 2016
Hi at all
i succeed !! thank's at all ...Andrew was right ... but i add an another
thing ; i have indicated in the dialogue box , under "default value" ,
in "relational value" the name of the layer B , the right field etc...
and now it's ok !
one more time , thank's !!
laurent
Le 21/12/2016 à 23:32, Andrew a écrit :
> Regarding the default values option/limitations, I can add that if you
> try to use the default values expression dialog to build an expression
> using geomintersects() the dialog will evaluate the expression as
> invalid.  Instead, build the expression in the field calculator and
> then copy/paste it into default value box and skip using the
> expression dialog.
> Andrew
> On Wed, Dec 21, 2016 at 1:32 PM, DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>> wrote:
>     Hi,
>     Laurent, I can think about different ways you can test to tackle
>     your issues, provided you have two spatial layers that overlap
>     (and without any intermediate layer creation):
>     - recent QGIS introduce default values concept
>     (http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#common-settings
>     <http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#common-settings>)
>     - i'm not really sure about its limitations though
>     - add a virtual field
>     (http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html#editing-attribute-values
>     <http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html#editing-attribute-values>)
>     that you could later recalculate into a simple field
>     - use the Autofields plugin
>     (http://plugins.qgis.org/plugins/AutoFields/
>     <http://plugins.qgis.org/plugins/AutoFields/>)
>     - use the SpatialJoin plugin
>     (http://plugins.qgis.org/plugins/spatialJoin/
>     <http://plugins.qgis.org/plugins/spatialJoin/>)
>     Except the SpatialJoin plugin option (which is internally based on
>     it), you'll need to write an expression likely based on
>     refFunctions plugin (e.g, geomintersects) someone mentioned above.
>     HTH,
>     Harrissou
>     2016-12-21 19:23 GMT+01:00 Laurent Bourlet
>     <laurentbourlet34 at gmail.com <mailto:laurentbourlet34 at gmail.com>>:
>         Hi,
>         i thought it was more easy ...
>         In fact , i don't use a GPS because these points don't need
>         precision : they are only used to identify the parcels . And i
>         would like to catch their identity ( a number for each parcel
>         and the owner ) if possible with a dynamic spatialjoin...
>         With booth data ( number of parcel and name of owner ) , i
>         could talk with the fisc administration :-)
>         Randy was right ...i didn't have the same EPSG for the two
>         layers . It's now OK ! but without the feature "dynamic" .
>         Indeed , i would avoid building many temporaries layers and i
>         thought it existed a plugin for this " dynamic" feature.
>         If no , i will ask my users to make spatialjoins some time to
>         time ...
>         Waiting , i will try the solution of Bernd...
>         Thank you anyway !
>         laurent
>         Le 21/12/2016 à 17:46, Bernd Vogelgesang a écrit :
>             Hi,
>             for me this sounds more like he is getting new points once
>             in a while and
>             wants to join those attributes to the new points
>             "automatically" from the
>             parcel layer.
>             The biggest problem for users is to rethink the workflow
>             from the end to
>             the beginning and to know the limitations.
>             The outcome should be a point layer with the polygons
>             attributes. If those
>             points (layer A) are from GPS as Randy assumes, they have
>             to be
>             reprojected to the parcels layer (layer B) before being
>             able to join them
>             spatially(layer C). The spatial join in the toolbox
>             produces layer D.
>             Most probably, the resulting layer D is going to to be
>             edited in some way
>             (adding notes about size, the progress, classifications,
>             whatever), so you
>             will have to find a way to preserve those new attribute
>             while being able to
>             add new points without much trouble.
>             The processing toolbox is a good way to do these steps,
>             though it produces
>             a lot of temporary files cluttering the project.
>             A better way for all those repetitive tasks, is to use the
>             graphical
>             modeller, to create a workflow which only has to be
>             triggered once new
>             points come in, and the resulting file can be saved as new
>             a file e.g.
>             with the current date in the name, so you have kind of an
>             archive and do not
>             overwrite previous files (and destroy your work in case
>             something goes
>             wrong).
>             So I can imagine a model with input layer A (new points in
>             WGS84 without attributes) and a parcel layer B (in
>             whatever projection).
>             reproject layer A and C will be created as an intermediate
>             step.
>             Next input layer is the latest result layer D, reprojected
>             and with attributes.
>             Merge layer C and D -> E. Now delete all columns which are
>             from layer B (from the last spatial join. Unfortunately,
>             you can only delete one field at a time in the modeller,
>             so you'll will have to add the command several times in a
>             row to the model) -> Fn
>             Do the spatial join of Fn with B.
>             The last result G will now hold all points with the
>             corresponding parcel info plus additional fields you might
>             have added to the points.
>             G will be the input D in the next run with fresh points.
>             So, do not add new points to the already existing
>             collection of points in WGS84 (it is never save to edit
>             layers without backup), but just import them as a new
>             input set and then run the model with the parcel layer and
>             the last result layer.
>             The modeller is not as intuitive as it should be, but it
>             can save you a lot of time once you managed to set up a model.
>             Maybe I was completely wrong analysing the problem, but
>             maybe someone else has the problem that fits to my solution ;)
>             Cheers
>             Bernd
>             Am 21.12.2016, 14:07 Uhr, schrieb Randal Hale
>             <rjhale at northrivergeographic.com
>             <mailto:rjhale at northrivergeographic.com>>:
>                 2 things:
>                 1. In QGIS there is a processing toolbox (I assume you
>                 are one something as new as version 2.14.8). Open it
>                 (it's at the top -> Processing -> Toolbox). You can
>                 search for tools. Search for "join" and you should see
>                 a "Join Attributes by location". This is a spatial join.
>                 2. THE MOST IMPORTANT THING. You mentioned you had
>                 collected points with a GPS. Possibly these points are
>                 in EPSG:4326. I'm going to guess that your parcel
>                 layer isn't. If you right click your parcel layer (in
>                 the layers panel) it will allow you to select
>                 properties. On the General Tab you will see the
>                 Coordinate Reference System mentioned and many times
>                 it is something like EPSG:xxxx . A Spatial Join must
>                 have the layers in the same coordinate system.
>                 If it is different - Right Click on your GPS points
>                 and "Save as". When the "Save vector layer as...."
>                 window comes up. Save it as a shapefile and MOST
>                 IMPORTANTLY change the CRS to match your parcel layer.
>                 Click on the small globe (that appears to be wearing a
>                 hat) and in the filter type in the number you see for
>                 your parcels. You can then select that projection and
>                 Save your file. It should save. You can then perform
>                 the "join by location".
>                 It should work. You are very close though so don't worry.
>                 Randy
>                 On 12/21/2016 01:24 AM, Erwan Conseil wrote:
>                     Hi
>                     In my layer B , I have the name of the owner and
>                     the number of the parcel : this number , a polygon
>                     , have a WKT location . All this is in a SHP . As
>                     I grab points in layer A directly in Qgis (2.18) ,
>                     I have also a SHP . And i need a dynamic join
>                     because I have no desire to make the spatial join
>                     each time...
>                     Regards
>                     Laurent
>                         Le 21 déc. 2016 à 01:30, Randal Hale
>                         <mailto:rjhale at northrivergeographic.com>> a
>                         écrit :
>                         In your layer B - Do the Names of the Owners
>                         have a location (like a tax parcel) or are
>                         they a spreadsheet (like Microsoft Excel)?
>                         Randy
>                             On 12/20/2016 06:03 PM, Laurent Bourlet wrote:
>                             Hi at all
>                             I'm a beginner in Qgis and i would make a
>                             In fact , i have created a vector layer (
>                             for example  A) and i grab points in it
>                             when I'm outdoor ( these points are
>                             buildings unknowned by the government and
>                             so these building are not taxed ...) . I
>                             have also a layer (B) with the name of the
>                             owners of these lands .
>                             You see what i would ?...
>                             I would have these names transferred as
>                             attribut from B to A .
>                             For that , i think about a spatialjoin
>                             with a dynamic feature . So i have
>                             downloaded the two plugins "reffunction"
>                             and "spatialjoin".
>                             But i have certainly maked something wrong
>                             because i don't succeed ...
>                             Is it the good method ?
>                             And If yes , and if exist a doc about
>                             these plugins ...i'll take it :-))
>                             regards
>                             Laurent
>                             ( pour les francophones ...je repère et
>                             saisis des points représentants des
>                             batiments construits et visibles par
>                             Google Map mais inconnus par le cadastre
>                             et donc les impôts ...je voudrais donc
>                             enrichir la couche de saisie par les
>                             références des parcelles et les noms des
>                             propriétaires par une jointure spatiale
>                             dynamique ..à chaque point saisi , "monte"
>                             cette référence )
>                             _______________________________________________
>                             Qgis-user mailing list
>                             Qgis-user at lists.osgeo.org
>                             <mailto:Qgis-user at lists.osgeo.org>
>                             List info:
>                             http://lists.osgeo.org/mailman/listinfo/qgis-user
>                             <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>                             Unsubscribe:
>                         Randal Hale
>                         North River Geographic Systems, Inc
>                         http://www.northrivergeographic.com
>                         <http://www.northrivergeographic.com>
>                         423.653.3611 rjhale at northrivergeographic.com
>                         twitter:rjhale
>                         List info:
>                         Unsubscribe:
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>         Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161222/cbaa21e8/attachment.html>
