[Qgis-user] spatialjoin
Randal Hale rjhale at northrivergeographic.com
Thu Dec 22 05:36:40 PST 2016
Congrats - sorry I was almost leading own a more labor intensive path.
So now I have a question? I'm on QGIS 2.18 on Linux - Where is
geomintersects()?  I don't see it in Field calculator as something I can
use (I have a lot of geom functions) but just not that currently. I was
reading back through all the emails and maybe I'm missing something (I
haven't tried my windows version yet).
Thanks in Advance,
Randy
On 12/22/2016 03:26 AM, Laurent Bourlet wrote:
> Hi at all
> i succeed !! thank's at all ...Andrew was right ... but i add an
> another thing ; i have indicated in the dialogue box , under "default
> value" , in "relational value" the name of the layer B , the right
> field etc... and now it's ok !
> one more time , thank's !!
> laurent
> Le 21/12/2016 à 23:32, Andrew a écrit :
>> Regarding the default values option/limitations, I can add that if
>> you try to use the default values expression dialog to build an
>> expression using geomintersects() the dialog will evaluate the
>> expression as invalid.  Instead, build the expression in the field
>> calculator and then copy/paste it into default value box and skip
>> using the expression dialog.
>> Andrew
>> On Wed, Dec 21, 2016 at 1:32 PM, DelazJ <delazj at gmail.com
>> <mailto:delazj at gmail.com>> wrote:
>>     Hi,
>>     Laurent, I can think about different ways you can test to tackle
>>     your issues, provided you have two spatial layers that overlap
>>     (and without any intermediate layer creation):
>>     - recent QGIS introduce default values concept
>>     (http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#common-settings
>>     <http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#common-settings>)
>>     - i'm not really sure about its limitations though
>>     - add a virtual field
>>     (http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html#editing-attribute-values
>>     <http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html#editing-attribute-values>)
>>     that you could later recalculate into a simple field
>>     - use the Autofields plugin
>>     (http://plugins.qgis.org/plugins/AutoFields/
>>     <http://plugins.qgis.org/plugins/AutoFields/>)
>>     - use the SpatialJoin plugin
>>     (http://plugins.qgis.org/plugins/spatialJoin/
>>     <http://plugins.qgis.org/plugins/spatialJoin/>)
>>     Except the SpatialJoin plugin option (which is internally based
>>     on it), you'll need to write an expression likely based on
>>     refFunctions plugin (e.g, geomintersects) someone mentioned above.
>>     HTH,
>>     Harrissou
>>     2016-12-21 19:23 GMT+01:00 Laurent Bourlet
>>     <laurentbourlet34 at gmail.com <mailto:laurentbourlet34 at gmail.com>>:
>>         Hi,
>>         i thought it was more easy ...
>>         In fact , i don't use a GPS because these points don't need
>>         precision : they are only used to identify the parcels . And
>>         i would like to catch their identity ( a number for each
>>         parcel and the owner ) if possible with a dynamic spatialjoin...
>>         With booth data ( number of parcel and name of owner ) , i
>>         could talk with the fisc administration :-)
>>         Randy was right ...i didn't have the same EPSG for the two
>>         layers . It's now OK ! but without the feature "dynamic" .
>>         Indeed , i would avoid building many temporaries layers and i
>>         thought it existed a plugin for this  " dynamic" feature.
>>         If no , i will ask my users to make spatialjoins some time to
>>         time ...
>>         Waiting , i will try the solution of Bernd...
>>         Thank you anyway !
>>         laurent
>>         Le 21/12/2016 à 17:46, Bernd Vogelgesang a écrit :
>>             Hi,
>>             for me this sounds more like he is getting new points
>>             once in a while and
>>             wants to join those attributes to the new points
>>             "automatically" from the
>>             parcel layer.
>>             The biggest problem for users is to rethink the workflow
>>             from the end to
>>             the beginning and to know the limitations.
>>             The outcome should be a point layer with the polygons
>>             attributes. If those
>>             points (layer A) are from GPS as Randy assumes, they have
>>             to be
>>             reprojected to the parcels layer (layer B) before being
>>             able to join them
>>             spatially(layer C). The spatial join in the toolbox
>>             produces layer D.
>>             Most probably, the resulting layer D is going to to be
>>             edited in some way
>>             (adding notes about size, the progress, classifications,
>>             whatever), so you
>>             will have to find a way to preserve those new attribute
>>             while being able to
>>             add new points without much trouble.
>>             The processing toolbox is a good way to do these steps,
>>             though it produces
>>             a lot of temporary files cluttering the project.
>>             A better way for all those repetitive tasks, is to use
>>             the graphical
>>             modeller, to create a workflow which only has to be
>>             triggered once new
>>             points come in, and the resulting file can be saved as
>>             new a file e.g.
>>             with the current date in the name, so you have kind of an
>>             archive and do not
>>             overwrite previous files (and destroy your work in case
>>             something goes
>>             wrong).
>>             So I can imagine a model with input layer A (new points
>>             in WGS84 without attributes) and a parcel layer B (in
>>             whatever projection).
>>             reproject layer A and C will be created as an
>>             intermediate step.
>>             Next input layer is the latest result layer D,
>>             reprojected and with attributes.
>>             Merge layer C and D -> E. Now delete all columns which
>>             are from layer B (from the last spatial join.
>>             Unfortunately, you can only delete one field at a time in
>>             the modeller, so you'll will have to add the command
>>             several times in a row to the model) -> Fn
>>             Do the spatial join of Fn with B.
>>             The last result G will now hold all points with the
>>             corresponding parcel info plus additional fields you
>>             might have added to the points.
>>             G will be the input D in the next run with fresh points.
>>             So, do not add new points to the already existing
>>             collection of points in WGS84 (it is never save to edit
>>             layers without backup), but just import them as a new
>>             input set and then run the model with the parcel layer
>>             and the last result layer.
>>             The modeller is not as intuitive as it should be, but it
>>             can save you a lot of time once you managed to set up a
>>             model.
>>             Maybe I was completely wrong analysing the problem, but
>>             maybe someone else has the problem that fits to my
>>             solution ;)
>>             Cheers
>>             Bernd
>>             Am 21.12.2016, 14:07 Uhr, schrieb Randal Hale
>>             <rjhale at northrivergeographic.com
>>             <mailto:rjhale at northrivergeographic.com>>:
>>                 2 things:
>>                 1. In QGIS there is a processing toolbox (I assume
>>                 you are one something as new as version 2.14.8). Open
>>                 it (it's at the top -> Processing -> Toolbox). You
>>                 can search for tools. Search for "join" and you
>>                 should see a "Join Attributes by location". This is a
>>                 spatial join.
>>                 2. THE MOST IMPORTANT THING. You mentioned you had
>>                 collected points with a GPS. Possibly these points
>>                 are in EPSG:4326. I'm going to guess that your parcel
>>                 layer isn't. If you right click your parcel layer (in
>>                 the layers panel) it will allow you to select
>>                 properties. On the General Tab you will see the
>>                 Coordinate Reference System mentioned and many times
>>                 it is something like EPSG:xxxx . A Spatial Join must
>>                 have the layers in the same coordinate system.
>>                 If it is different - Right Click on your GPS points
>>                 and "Save as". When the "Save vector layer as...."
>>                 window comes up. Save it as a shapefile and MOST
>>                 IMPORTANTLY change the CRS to match your parcel
>>                 layer. Click on the small globe (that appears to be
>>                 wearing a hat) and in the filter type in the number
>>                 you see for your parcels. You can then select that
>>                 projection and Save your file. It should save. You
>>                 can then perform the "join by location".
>>                 It should work. You are very close though so don't worry.
>>                 Randy
>>                 On 12/21/2016 01:24 AM, Erwan Conseil wrote:
>>                     Hi
>>                     In my layer B , I have the name of the owner and
>>                     the number of the parcel : this number , a
>>                     polygon , have a WKT location . All this is in a
>>                     SHP . As I grab points in layer A directly in
>>                     Qgis (2.18) , I have also a SHP . And i need a
>>                     dynamic join because I have no desire to make the
>>                     spatial join each time...
>>                     Regards
>>                     Laurent
>>                         Le 21 déc. 2016 à 01:30, Randal Hale
>>                         <mailto:rjhale at northrivergeographic.com>> a
>>                         écrit :
>>                         In your layer B - Do the Names of the Owners
>>                         have a location (like a tax parcel) or are
>>                         they a spreadsheet (like Microsoft Excel)?
>>                         Randy
>>                             On 12/20/2016 06:03 PM, Laurent Bourlet
>>                             wrote:
>>                             Hi at all
>>                             I'm a beginner in Qgis and i would make a
>>                             In fact , i have created a vector layer (
>>                             for example  A) and i grab points in it
>>                             when I'm outdoor ( these points are
>>                             buildings unknowned by the government and
>>                             so these building are not taxed ...) . I
>>                             have also a layer (B) with the name of
>>                             the owners of these lands .
>>                             You see what i would ?...
>>                             I would have these names transferred as
>>                             attribut from B to A .
>>                             For that , i think about a spatialjoin
>>                             with a dynamic feature . So i have
>>                             downloaded the two plugins "reffunction"
>>                             and "spatialjoin".
>>                             But i have certainly maked something
>>                             wrong because i don't succeed ...
>>                             Is it the good method ?
>>                             And If yes , and if exist a doc about
>>                             these plugins ...i'll take it :-))
>>                             regards
>>                             Laurent
>>                             ( pour les francophones ...je repère et
>>                             saisis des points représentants  des
>>                             batiments construits et visibles par
>>                             Google Map mais inconnus par le cadastre
>>                             et donc les impôts ...je voudrais donc
>>                             enrichir la couche de saisie par les
>>                             références des parcelles et les noms des
>>                             propriétaires par une jointure spatiale
>>                             dynamique ..à chaque point saisi ,
>>                             "monte" cette référence )
>>                             _______________________________________________
>>                             Qgis-user mailing list
>>                             Qgis-user at lists.osgeo.org
>>                             <mailto:Qgis-user at lists.osgeo.org>
>>                             List info:
>>                             http://lists.osgeo.org/mailman/listinfo/qgis-user
>>                             <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>                             Unsubscribe:
>>                         Randal Hale
>>                         North River Geographic Systems, Inc
>>                         http://www.northrivergeographic.com
>>                         <http://www.northrivergeographic.com>
>>                         423.653.3611 rjhale at northrivergeographic.com
>>                         twitter:rjhale
>>                         List info:
>>                         Unsubscribe:
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Unsubscribe:
>>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161222/666c2920/attachment.html>
