[Qgis-user] PROBLEM IN RUNNING DEM
Michael Treglia mtreglia at gmail.com
Wed Feb 17 07:55:36 PST 2016
Hi Ashish,
Can you please elaborate on what you did? What tool were you using, and
exactly what was your goal? (Was it something through the processing
toolbox? Or the main functions in QGIS?)
These errors kind of look like what I've seen when I use SAGA GIS through
the processing toolbox and operations fail - I often find some SAGA
functions work best when I use SAGA as a stand-alone tool.  It should be
installed with QGIS (on Windows you should be able to find it by searching
in your start menu... not sure offhand about mac/linux systems).
Alternatively, you could download (a newer version of) SAGA and install
that on its own as well: http://www.saga-gis.org/en/index.html
Again though, giving more details will help others give some advice.
Cheers,
Mike
On Wed, Feb 17, 2016 at 9:42 AM, Ashish Guruji <
ashish.guruji-polyced at msubaroda.ac.in> wrote:
> SYSTEM:32 BIT
> VERSON QGIS:2.6.1
> INSTALLED:JANUARY 2016
> ​MESSAGE CAME IN QGIS​
> Oooops! The following output layers could not be open
> ·                     Pit Removed Elevation Grid: D:/ashishgurujipolytechnic-20-6-14/ashishgurujipolytechnic-29-8-15/RESEARCH
> WORK/MSU RESEARCH CELL/BHUVAN DATA/cdnf43t/pit_rmv.tif
> The above files could not be opened, which probably indicates that they
> were not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not
> created as expected
> ·                     D8 Flow Direction Grid: D:/ashishgurujipolytechnic-20-6-14/ashishgurujipolytechnic-29-8-15/RESEARCH
> WORK/MSU RESEARCH CELL/BHUVAN DATA/cdnf43t/flow_drc.tif
> ·                     D8 Slope Grid: D:/ashishgurujipolytechnic-20-6-14/ashishgurujipolytechnic-29-8-15/RESEARCH
> WORK/MSU RESEARCH CELL/BHUVAN DATA/cdnf43t/flow_grid.tif
> created as expected
> IS THIS DUE TO LONG PATH OF FILE?
> Ashish Laxman Guruji
> Lecturer & Internal Co-ordinator
> Civil & CDTP(Community Development Through Polytechnic)
> Polytechnic
> The M.S.University of Baroda
> Near Shashtri Bridge
> Fateh gunj
> Vadodara-390002
> Ph:91-9904222832
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160217/25d06f26/attachment.html>
