[Qgis-user] CentOS or SuSE for QGIS?
Tudorache, Marian Marian.Tudorache at navcanada.ca
Wed Feb 17 09:06:05 PST 2016
I am not sure if you are still looking into this matter.
What about this? http://courses.neteler.org/qgis-2-10-rpms-for-fedora-21-centos-7-scientific-linux-7/
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Evert Groenewald
Sent: January-17-16 2:39 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] CentOS or SuSE for QGIS?
Hi Andreas
On 13/01/2016 13:40, Andreas Neumann wrote:
> Hi,
> At my new workplace I have the choice of CentOS or SuSE as a Linux
> distribution. I would have chosen Debian or Ubuntu, personally, but
> the other two are my choice.
You can look at the link below, it might help.
I do not know what the situation is in the CentOS repositories. On openSuse this is the choices from the Geo repository. Though I see CentOS 6 is listed as well.
http://download.opensuse.org/repositories/Application:/Geo/
Evert
> Which one is better for QGIS and FOSSGIS in general? What do you
> recommend? Or are they equally well suited?
> I intend to build from Source.
> Thanks,
> Andreas
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
