[Qgis-user] Prevent cut-off labels in composer
Neumann, Andreas a.neumann at carto.net
Wed Jun 1 01:44:20 PDT 2016
Hi Anita,
In the label settings tab in the very upper-right corner there is this
little button (4-way arrow with yellow cog-wheel) that leads to settings
for the labeling engine. I believe they are global to the project - not
sure if this is per layer.
In there, there is a checkbox "Show partial layers". If you tick that
off, there should be not cut-off labels.
Can you please test and report back if it works?
Andreas
On 2016-06-01 10:24, Anita Graser wrote:
> Hi,
> Is it already possible to prevent cut-off labels at map borders in print composer?
> Best wishes,
> Anita
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160601/7e0a41dd/attachment.html>
