[Qgis-user] Prevent cut-off labels in composer
Anita Graser
anitagraser at gmx.at
Wed Jun 1 02:30:12 PDT 2016
Hi Andreas,
Thanks a lot, that does the trick!
Best wishes,
Anita
On Wed, Jun 1, 2016 at 10:44 AM, Neumann, Andreas <a.neumann at carto.net>
wrote:
> Hi Anita,
> In the label settings tab in the very upper-right corner there is this
> little button (4-way arrow with yellow cog-wheel) that leads to settings
> for the labeling engine. I believe they are global to the project - not
> sure if this is per layer.
> In there, there is a checkbox "Show partial layers". If you tick that off,
> there should be not cut-off labels.
> Can you please test and report back if it works?
> Andreas
> On 2016-06-01 10:24, Anita Graser wrote:
> Hi,
> Is it already possible to prevent cut-off labels at map borders in print
> composer?
> Best wishes,
> Anita
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160601/a359fbb1/attachment.html>
