[Qgis-user] Antarctic polar stereographic graticules (composer)
Lester Anderson
arctica1963 at gmail.com
Wed Jun 1 08:14:06 PDT 2016
Hi Nicolas,
The problem is not so much with the grid as that displays fine. The issue
crops up with the map composer, and even with the grid as WGS-84 the same
problem persists. Looked at both North and South polar views and the 180
graticule is always missing irrespective of the increment used. The
latitude lines do not change and are clear line segments; these should be
smoother.
Data that are in UTM and with WGS-84 graticules look fine (smooth latitude
lines). Is there an issue with Polar views and graticules?
Lester
On 1 June 2016 at 11:41, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
wrote:
> Hi,
> Try saving the layer in WGS-84. Then make sure the project is also in the
> same projection. It can help sometimes to make a spatial index.
> Keep me posted.
> Nicolas
> On Jun 1, 2016 05:35, "Lester Anderson [via OSGeo.org] " <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5269320&i=0>> wrote:
> Hello,
> I had some Antarctic polar stereographic data and when applying a
> WGS-84 long-lat grid in map composer it generated most of the
> longitude lines (180 missing), and very crude latitude lines (clearly
> visible straight line segments).
> Is there any way to improve the latitude lines?
> Lester
> Tested in 2.10, 2.12, 2.14
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5269310&i=0">[hidden
> email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> *Ant2016.jpg* (38K) Download Attachment
> <http://osgeo-org.1560.x6.nabble.com/attachment/5269310/0/Ant2016.jpg>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Antarctic-polar-stereographic-graticules-composer-tp5269310.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: Antarctic polar stereographic
> <http://osgeo-org.1560.x6.nabble.com/Antarctic-polar-stereographic-graticules-composer-tp5269310p5269320.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160601/174069ef/attachment.html>
