[Qgis-user] Unable to project into NAD_1983_StatePlane_Georgia_West_FIPS_1002_Feet EPSG:102667
Ian Berdanier berdian at isu.edu
Sat Jun 4 19:31:33 PDT 2016
My project CRS is set to EPSG:102667. I am creating a model to first
reproject my DEM into the same. I am also reprojecting the polygon boundary
of my cadastral map that will be my clipping extent. When I run the
Reproject layer tool, having set the target CRS to the above projection, I
get the following: CRS was undefined: defaulting to EPSG:4326 - WGS84
Running similar with the DEM reports
Algorithm Warp (reproject) starting...
GDAL command:
gdalwarp -ot Float32 -t_srs EPSG:102667 -r near -of GTiff -co
COMPRESS=DEFLATE -co PREDICTOR=1 -co ZLEVEL=6
/home/berdian/QGISdata/HerringMill/ned19_n34x50_w083x75_ga_lanierlake_2010/ned19_n34x50_w083x75_ga_lanierlake_2010.img
/tmp/processing3a48a4e99ed3418ab475315f7bb618cd/890f47c859624b11ae53d9e1fdbdfadb/OUTPUT.tif
GDAL command output:
ERROR 6: EPSG PCS/GCS code 102667 not found in EPSG support files. Is this
a valid
EPSG coordinate system?
ERROR 1: Translating source or target SRS failed:
EPSG:102667
Converting outputs
Loading resulting layers
The following layers were not correctly generated.
   - Reprojected
You can check the log messages to find more information about the execution
of the algorithm
Any ideas why I can't project either into Georgia State Plane?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160604/312ae689/attachment.html>
