[Qgis-user] Unable to project into NAD_1983_StatePlane_Georgia_West_FIPS_1002_Feet EPSG:102667
Randal Hale rjhale at northrivergeographic.com
Sat Jun 4 19:38:15 PDT 2016
I'm wondering if you used EPSG:2240 it would work. I believe the 102667
is the ESRI version of Georgia West NAD83.
I think it should work regardless - possibly you've hit a bug.
On 06/04/2016 10:31 PM, Ian Berdanier wrote:
> My project CRS is set to EPSG:102667. I am creating a model to first
> reproject my DEM into the same. I am also reprojecting the polygon
> boundary of my cadastral map that will be my clipping extent. When I
> run the Reproject layer tool, having set the target CRS to the above
> projection, I get the following: CRS was undefined: defaulting to
> EPSG:4326 - WGS84
> Running similar with the DEM reports
> Algorithm Warp (reproject) starting...
> GDAL command:
> gdalwarp -ot Float32 -t_srs EPSG:102667 -r near -of GTiff -co
> COMPRESS=DEFLATE -co PREDICTOR=1 -co ZLEVEL=6
> /home/berdian/QGISdata/HerringMill/ned19_n34x50_w083x75_ga_lanierlake_2010/ned19_n34x50_w083x75_ga_lanierlake_2010.img
> /tmp/processing3a48a4e99ed3418ab475315f7bb618cd/890f47c859624b11ae53d9e1fdbdfadb/OUTPUT.tif
> GDAL command output:
> ERROR 6: EPSG PCS/GCS code 102667 not found in EPSG support files. Is
> this a valid
> EPSG coordinate system?
> ERROR 1: Translating source or target SRS failed:
> EPSG:102667
> Converting outputs
> Loading resulting layers
> The following layers were not correctly generated.
>   * Reprojected
> You can check the log messages to find more information about the
> execution of the algorithm
> Any ideas why I can't project either into Georgia State Plane?
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
https://www.facebook.com/NRGSInc
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160604/93dd05c2/attachment.html>
