[Qgis-user] seeking help on QGIS symbology for clorepleth maps
Neumann, Andreas
a.neumann at carto.net
Tue Jun 14 00:49:51 PDT 2016
Hi Kuan,
There is a newer manual available (still under development), targetting
version 2.14. You can find it at http://docs.qgis.org/testing/en/docs/
For your specific problem - have a look at the "Size assistant":
http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#proportional-symbol-and-multivariate-analysis
When you complain about the poor state of documentation, there are
multiple ways of contributing:
- help improving the documentation by providing pull requests
- donate some money so others can work on documentation
- hire a person that improves certain aspects of the documentation
Please do not compare ArcGIS with QGIS documentation - because ArcGIS
documentation is created from a company with approx. 3200 employees and
annual revenues >1 billion US $ per year, whereas QGIS is run primarily
from part-time developers and volunteers - with available funds and
sponsored development in the lower 6 figure euros per year - distributed
over several companies and the global QGIS.ORG organization.
Also - please understand that - unlike some other companies or projekcts
- QGIS is not copying ArcGIS - so it is quite natural that the terms are
different, as well as the UI
Finally: QGIS is not a product. It is a project - and everybody is
welcome to improve and contribute.
Hope this helps,
Andreas
On 2016-06-14 09:25, Kuan Song wrote:
> Dear community,
> I hope to seek help with QGIS functionality on symbology. The goal is to create simple maps with variable-sized symbols for a polygon map. For example: a map of counties, with bubbles on top indicating the population size in each county. This can be very easily with ArcMap, but is not very easy with QGIS.
> Yes I know it should be under the 'styles' tab, and it has something to do with adding a new symbol. But the part that's baffling with the user interface is: how do I link a symbol size to a data column in the data shapefile?
> Yes I know there is a QGIS manual. However, the current manual is very outdated. Many parts of it are simply copies of the manual from older versions, and are utterly useless. For example: http://docs.qgis.org/2.8/en/docs/training_manual/basic_map/symbology.html shows a different UI layout to the current software 2.14.
> This is a trivial and elementary problem. I feel ashamed asking this question. I'm sure many people have encountered it before. Could someone point me to a page where I can find a walk-through with actual screenshots of the current QGIS version? That'll be very helpful.
> Thank you.
> And again, to the QGIS developers: Please do not let poor documentation ruin a fine software product......
> Yours
> Kuan
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160614/8c80a157/attachment.html>
