[Qgis-user] Installing map server + Lizmap on Ubuntu 16.04
kimaidou kimaidou at gmail.com
Tue Jun 14 06:01:33 PDT 2016
Indeed, we have not yet ported Lizmap for PHP 7, even if it must be pretty
straitforward...
If you can begin from scratch, I will advise you to use Debian Jessie
(stable version) instead of Ubuntu.
To help in the process, we have added a new repository in Github to run
Lizmap from docker :
https://github.com/3liz/lizmap-docker/
We will also release soon our Ansible scripts to deploy a full Lizmap/QGIS
Server/PostgreSQL stack on a fresh Debian Jessie / Centos 7 server.
We also need to integrate the INSTALL.md content in Lizmap documentation,
because the installation process has changed a bit since version 3.0
https://github.com/3liz/lizmap-web-client/blob/master/INSTALL.md
Regards
Michaƫl
2016-06-13 18:58 GMT+02:00 virtusmankind <gas1985 at libero.it>:
> Hello everybody
> I'm a newbie using Linux OS. I'd like to set up a full working installation
> of map server (Apache + QGis Server) and Lizmap Web Client on my PC (and
> then on a virtual server) mounting Ubuntu 16.04.
> I cannot perform a working installation using Lizmap guide (found both on
> http://docs.3liz.com/it/admin_guide/installation/server_configuration.html
> and
> https://github.com/3liz/lizmap-documentation/blob/master/source/install/linux.srt
> I can't install php5 (on Ubuntu 16.04 seems to be installed php7 by
> default)
> I can't get an answer a GetCapabilities request from here:
> http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> I can't see nothing from  http://localhost/lm/ <http://localhost/lm/>
>  test
> page
> I'd like to install new Lizmap 3 but it could be a succes if I can
> configure
> version 2 now!
> Please support me step by step!
> Thanks in advance
> http://osgeo-org.1560.x6.nabble.com/Installing-map-server-Lizmap-on-Ubuntu-16-04-tp5271440.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160614/8f47c12f/attachment.html>
