[Qgis-user] How to import/convert *.ige files
Michael Treglia
mtreglia at gmail.com
Tue Jun 14 12:02:25 PDT 2016
Hi Douwe,
I've re-added the QGIS-User-List to the thread, so others can find the
answers/full thread in the archives. There's a 28 kb file that looks like
an img, though it does not have the extension displayed based on your local
pc configurations. (The icon with the file looks like an img).
To show the extension on all files, in the Control Panel (displayed as
Icons), go to Folder Options - 'View' tab, and uncheck the box for 'Hide
Extensions for Known File types'
Hope that helps -
mike
On Tue, Jun 14, 2016 at 2:55 PM, Douwe van Rees <douwevanrees at xs4all.nl>
wrote:
> Hello Mike,
> Thanks for your help. I downloaded the data again with the same result, no
> *.img file included. I have attached a screenshot with the data files, the
> only one I’m able to open in QGIS is a .shp file in the Metadata directory
> (apparently with the changes in land cover from 2001 to 2011, which I don’t
> need at the moment). I’m using Winrar to unzip, no particularities as far
> as I know….. I have also unzipped the compressed file using the 7-zip app,
> same results again. That’s why I don’t believe anything is wrong with the
> download, but maybe I’m mistaken. Thanks again in advance for your trouble!
> Best regards,
> Douwe
> *Van:* Michael Treglia [mailto:mtreglia at gmail.com]
> *Verzonden:* dinsdag 14 juni 2016 17:27
> *Aan:* Douwe van Rees <douwevanrees at xs4all.nl>
> *CC:* qgis-user at lists.osgeo.org
> *Onderwerp:* Re: [Qgis-user] How to import/convert *.ige files
> The file should come with a .img file - as noted in a stack exchange
> answer, "The ige file is just an indexing file to address large files
> that exceed 32bit addressing space. The file that you work with is the
> img." (
> http://gis.stackexchange.com/questions/55299/mysterious-problems-with-ige-file
> For NLCD 2011 data, I just drag and drop the IMG file into QGIS, and it
> opens right away, with the appropriate color pallet and such. If that
> doesn't work, maybe try re-downloading, as sometimes if a giant download
> gets interrupted it could lead to the file getting corrupted.
> Hope that helps!
> Mike
> On Tue, Jun 14, 2016 at 7:49 AM, Douwe van Rees <douwevanrees at xs4all.nl>
> wrote:
> Hi,
> I’m looking for a way to import Erdas image files (NLCD 2011 data) with
> *.ige (> 4 GB) in QGIS 2.14 . As I understand the *.ige is a file extension
> used for large files, I have tried to import it as a raster layer but the
> file format is not valid. Thanks for your assistance!
> Kind regards,
> Douwe van Rees
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160614/f6448b53/attachment.html>
