[Qgis-user] [UFC : PUB]Qgis-user Digest, Vol 124, Issue 33
Patrick Giraudoux
patrick.giraudoux at univ-fcomte.fr
Sun Jun 19 23:08:41 PDT 2016
Le 19/06/2016 à 21:00, qgis-user-request at lists.osgeo.org a écrit :
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. QGIS GRASS PLUGIN 7 (Paul Shapley)
> 2. Boundlessgeo QGIS (Pieter du Plooy)
> 3. How do you all upload your webmaps? (Tom Chadwin)
> 4. Re: How do you all upload your webmaps? (Andreas Neumann)
> 5. Re: How do you all upload your webmaps? (Tom Chadwin)
> 6. Re: How do you all upload your webmaps? (Heikki Vesanto)
> 7. Re: plugin manager crash (Herbert Carl Meyer)
> 8. Virus ( Trojan.Gen.SMH) detected by Symantec in QGIS 2.14.3
> 32 bits (Patrick Giraudoux)
> 9. Re: Virus ( Trojan.Gen.SMH) detected by Symantec in QGIS
> 2.14.3 32 bits (Matthias Kuhn)
> Message: 1
> Date: Sat, 18 Jun 2016 22:12:46 +0100
> From: Paul Shapley <p.shapley at gmail.com>
> To: qgis-user List <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] QGIS GRASS PLUGIN 7
> Message-ID:
> <CAK-x10mbgjm6X=yYHEKK-Q_6TUeYCSV2qzCybZnNwQAdKdGQ1g at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Users,
> I'm getting the following plugin error when starting QGIS 2.14.3 'Essen' on
> Ubuntu 16.04 LTS. I have Grass 7.0.4 installed from the ubuntugis-unstable
> repository and QGIS from the debian-nightly-release repository. The error
> reads:
> "Failed to load /usr/lib/qgis/plugins/libgrassplugin7.so (Reason: Cannot
> load library /usr/lib/qgis/plugins/libgrassplugin7.so: (
> libgrass_gis.7.0.3.so: cannot open shared object file: No such file or
> directory))"
> It seems as though QGIS cannot find the location of the Grass Libraries
> needed to load the QGIS GRASS PLUGIN. As i understand this i need to create
> a new config file placed in /etc/ld.so.conf.d/something.conf with a path to
> the Grass libs and then activate the new config file using 'sudo ldconfig'.
> I'm not sure which path should be entered into the config file. Should it
> read:
> /usr/lib
> # or
> # which contains the
> libgrassplugin7.so/libgrassprovider7.so/libgrassrasterprovider7.so)
> # or
> /usr/lib/grass70/lib
> # this directory contains the libgrass_gis.7.0.4.so file
> or some combination of these paths.
> There may be another simpler alternative someone may be aware of for
> example using 'export LD_LIBRARY_PATH=/path/to/local/libs', if so can
> someone let me know which approach works best.
> Many Thanks,
> Paul Shapley
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160618/bcb25f22/attachment-0001.html>
> Message: 2
> Date: Sun, 19 Jun 2016 08:42:30 +0200
> From: Pieter du Plooy <pjduplooy at zpanelcp.com>
> To: qgis-user at lists.osgeo.org, qgis-developer at lists.osgeo.org
> Subject: [Qgis-user] Boundlessgeo QGIS
> Message-ID:
> <CAMDQVi4zB=NBEYLK-fjMxBFafe7c8VUrin4bNP9fMXEHFQgrNw at mail.gmail.com>
> Hi guys
> Im posting this in the users and dev forums in the hope that someone who
> knows someone at Boundless reads this.
> I can contact them, but its probably out of normal hours, so will probably
> only get an answer tomorrow, and I need an answer quicker than that.
> I have been struggling in vain to download the Boundless 2.14.1 Windows
> QGIS since last night at around 2100 UTC. Download stops at 79KB out of
> 770MB.
> I need this specific version, in order to demonstrate to the bosses at work
> the Windows and Mac versions in terms of functionality.
> I hope anyone can help me, and sorry for posting this in these mailing
> lists, but am being desperate lol.
> Regards.
> Pieter
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160619/43aa582d/attachment-0001.html>
> Message: 3
> Date: Sun, 19 Jun 2016 01:59:42 -0700 (PDT)
> From: Tom Chadwin <tom.chadwin at nnpa.org.uk>
> Subject: [Qgis-user] How do you all upload your webmaps?
> Message-ID: <1466326782573-5272348.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hello all
> At FOSS4GUK2016, I think it became apparent that a feature missing in
> qgis2web is integrated publishing. I'd like to implement it, but there are
> many ways of uploading files to the web. I'd like to know what some of you
> do:
> 1. Online form as part of web content management system such as WordPress,
> Drupal, etc.
> 2. Online form as part of hosting package, eg AWS, cPanel, Plesk, etc
> 3. FTP
> 4. SFTP
> 5. SCP
> 6.FTPS
> 7. Github
> 8. Other (please state)
> Any info I can get from you will be extremely useful.
> Thanks
> Tom
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-do-you-all-upload-your-webmaps-tp5272348.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Message: 4
> Date: Sun, 19 Jun 2016 13:14:09 +0200
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] How do you all upload your webmaps?
> Message-ID: <57667E81.4080101 at carto.net>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Hi Tom,
> I personally use SCP/SFTP, as I use a Linux/Apache server combination.
> There are so many ways to deploy the generated web map, that I
> personally think, you shouldn't include this in the plugin. For the same
> reason, QGIS web client doesn't have a deploy script. There are too many
> combinations of OS/Web server to deal with. Always someone will have a
> different configuration - as the mailing lists show.
> It shouldn't be a big hurdle for the user to copy a folder over to the
> webserver. Maybe a message that the folder needs to be uploaded to the
> webserver should be enough.
> This is just my personal opinion. If there happens to be a common,
> preferred way, it may still be worth having the upload/deployment
> implemented by the plugins.
> Curious to see what other people think.
> Andreas
> On 19.06.2016 10:59, Tom Chadwin wrote:
>> Hello all
>> do:
>> Drupal, etc.
>> 3. FTP
>> 4. SFTP
>> 5. SCP
>> 6.FTPS
>> 7. Github
>> Thanks
>> Tom
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Message: 5
> Date: Sun, 19 Jun 2016 05:36:01 -0700 (PDT)
> Message-ID: <1466339761891-5272367.post at n6.nabble.com>
> Your opinion had been mine, but more than one QGIS user looked very
> discouraged when I answered their question "How do I get my qgis2web map
> online?"
> We are up against the end-to-end ArcGIS Online ease of use, in my opinion.
> As you say, if we can help a significant proportion of users, it should be
> considered.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-do-you-all-upload-your-webmaps-tp5272348p5272367.html
> Message: 6
> Date: Sun, 19 Jun 2016 14:38:08 +0100
> From: Heikki Vesanto <heikki.vesanto at gmail.com>
> To: Tom Chadwin <tom.chadwin at nnpa.org.uk>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
> <CAFTGJ2AATpJSGk2yHK5azaAbxU0GSKC_PC5OP3gg3Y29s4nT+Q at mail.gmail.com>
> Hi Tom,
> I use FTP or CPanel. I like seeing a full preview before uploading though.
> I think if you are able to sign up for hosting you can probably figure out
> copying the files over.
> I wonder if GitHub Pages might be an option? https://pages.github.com/
> -Heikki
> On 19 Jun 2016 1:52 p.m., "Tom Chadwin" <tom.chadwin at nnpa.org.uk> wrote:
>> online?"
>> considered.
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160619/3379e156/attachment-0001.html>
> Message: 7
> Date: Sun, 19 Jun 2016 10:42:37 -0400
> From: Herbert Carl Meyer <hcmeyer at gmail.com>
> Subject: Re: [Qgis-user] plugin manager crash
> Message-ID:
> <CAEYGmbaYwaiJNseWnBV3Hb8W963NCEwfsmthEy6=_n1gQjXc8g at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> The latest batch of Fedora 24 updates (2016.06.19) fixed the
> underlying problem. There were a large number of updates, including
> python and qt, so I do not know which of them fixed it. I can now
> display the plugin manager.
> Also, the splash screen now displays well. It was previously showing
> as a full screen image.
> So I do not have to install 5g of debug symbols to diagnose. Thank you.
> Message: 8
> Date: Sun, 19 Jun 2016 17:00:58 +0200
> From: Patrick Giraudoux <patrick.giraudoux at univ-fcomte.fr>
> Subject: [Qgis-user] Virus ( Trojan.Gen.SMH) detected by Symantec in
> QGIS 2.14.3 32 bits
> Message-ID: <961a1e20-93a1-ab26-cf4a-13ad2516721c at univ-fcomte.fr>
> Just to signal that I cannot install QGIS 2.14.3 (32 bits) with
> QGIS-OSGeo4W-2.14.3-2-Setup-x86.exe (stand-alone) on Windows 7. Symantec
> antivirus detect qgis.bin.exe as Trojan.Gen.SMH and put it in vault
> (which, of course prevents the sofwtare from working...). Mabe a false
> positive but it leads to a dedalock when is comes to use QGIS 32 bits.
> Installing QGIS-OSGeo4W-2.14.3-2-Setup-x86_64.exe (stand-alone) works
> fine with no problem.
> Cheers,
> Patrick
> Message: 9
> Date: Sun, 19 Jun 2016 18:46:40 +0200
> From: Matthias Kuhn <matthias at opengis.ch>
> Subject: Re: [Qgis-user] Virus ( Trojan.Gen.SMH) detected by Symantec
> in QGIS 2.14.3 32 bits
> Message-ID: <5766CC70.8030508 at opengis.ch>
> Hi Patrick
>> Symantec antivirus detect qgis.bin.exe as Trojan.Gen.SMH and put it in
>> vault (which, of course prevents the sofwtare from working...). Mabe a
>> false positive but it leads to a dedalock when is comes to use QGIS 32
>> bits.
> This has been reported in the past and is - if I understand correctly -
> related to heuristics. If you have a support contract with symantec, it
> would be great if you could ask them if they could adjust their
> heuristics (or provide details about what needs to be done to pass their
> tests). I am not aware of anything we could do from our side without
> more information from the provider of the anti virus software.
> https://www.symantec.com/security_response/writeup.jsp?docid=2013-041522-2144-99
> Thanks
> Matthias
I have sent them a report already mentioning that it should be a false
positive, but I do not know how (if) they follow up. Now the only
foreseen solution is to use the 64 bits version that is not detected as
viral.
Best,
Patrick
