[Qgis-user] Installing map server + Lizmap on Ubuntu 16.04
Daniel Vicente Lühr Sierra
dluhr at ieee.org
Mon Jun 20 11:43:15 PDT 2016
Any progress with porting Lizmap to PHP7?
I have been able to run most of it, but administration forms
(create/modify repos, etc.) show empty pages.
Also, any advice on sample apache .conf files would be appreciated.
Regards,
El 14/06/16 a las 09:01, kimaidou escribió:
> Hi,
> Indeed, we have not yet ported Lizmap for PHP 7, even if it must be
> pretty straitforward...
> If you can begin from scratch, I will advise you to use Debian Jessie
> (stable version) instead of Ubuntu.
> To help in the process, we have added a new repository in Github to
> run Lizmap from docker :
> https://github.com/3liz/lizmap-docker/
> We will also release soon our Ansible scripts to deploy a full
> Lizmap/QGIS Server/PostgreSQL stack on a fresh Debian Jessie / Centos
> 7 server.
> We also need to integrate the INSTALL.md content in Lizmap
> documentation, because the installation process has changed a bit
> since version 3.0
> https://github.com/3liz/lizmap-web-client/blob/master/INSTALL.md
> Regards
> Michaël
> 2016-06-13 18:58 GMT+02:00 virtusmankind <gas1985 at libero.it
> <mailto:gas1985 at libero.it>>:
> Hello everybody
> I'm a newbie using Linux OS. I'd like to set up a full working
> installation
> of map server (Apache + QGis Server) and Lizmap Web Client on my
> PC (and
> then on a virtual server) mounting Ubuntu 16.04.
> I cannot perform a working installation using Lizmap guide (found
> both on
> http://docs.3liz.com/it/admin_guide/installation/server_configuration.html
> <http://docs.3liz.com/it/admin_guide/installation/server_configuration.html>
> and
> https://github.com/3liz/lizmap-documentation/blob/master/source/install/linux.srt
> <https://github.com/3liz/lizmap-documentation/blob/master/source/install/linux.srt>
> I can't install php5 (on Ubuntu 16.04 seems to be installed php7
> by default)
> I can't get an answer a GetCapabilities request from here:
> http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> <http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
> I can't see nothing from http://localhost/lm/
> <http://localhost/lm/> test
> page
> I'd like to install new Lizmap 3 but it could be a succes if I can
> configure
> version 2 now!
> Please support me step by step!
> Thanks in advance
> http://osgeo-org.1560.x6.nabble.com/Installing-map-server-Lizmap-on-Ubuntu-16-04-tp5271440.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
IEEE Member
IEEE UACh Student Branch Counselor
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160620/f71cebec/attachment.html>
