[Qgis-user] Installing map server + Lizmap on Ubuntu 16.04
Daniel Vicente Lühr Sierra
dluhr at ieee.org
Tue Jun 21 07:14:26 PDT 2016
El 20/06/16 a las 14:43, Daniel Vicente Lühr Sierra escribió:
> Hi,
> Any progress with porting Lizmap to PHP7?
> I have been able to run most of it, but administration forms
> (create/modify repos, etc.) show empty pages.
I'm sorry, I was running the 3.0.1 release, and I didn't noticed, the
php7 issue has been patched in the repository. I just applied the patch
by hand, and everything seems to work.
> Also, any advice on sample apache .conf files would be appreciated.
Without a very "deep" knowledge of apache2 configurations, it runs with
a very basic site.conf file.
I do have another question about performance loading postgis layers, but
I will send open a different thread for that.
> Regards,
> El 14/06/16 a las 09:01, kimaidou escribió:
>> Hi,
>> Indeed, we have not yet ported Lizmap for PHP 7, even if it must be
>> pretty straitforward...
>> If you can begin from scratch, I will advise you to use Debian Jessie
>> (stable version) instead of Ubuntu.
>> To help in the process, we have added a new repository in Github to
>> run Lizmap from docker :
>> https://github.com/3liz/lizmap-docker/
>> We will also release soon our Ansible scripts to deploy a full
>> Lizmap/QGIS Server/PostgreSQL stack on a fresh Debian Jessie / Centos
>> 7 server.
>> We also need to integrate the INSTALL.md content in Lizmap
>> documentation, because the installation process has changed a bit
>> since version 3.0
>> https://github.com/3liz/lizmap-web-client/blob/master/INSTALL.md
>> Regards
>> Michaël
>> 2016-06-13 18:58 GMT+02:00 virtusmankind <gas1985 at libero.it
>> <mailto:gas1985 at libero.it>>:
>> Hello everybody
>> I'm a newbie using Linux OS. I'd like to set up a full working
>> installation
>> of map server (Apache + QGis Server) and Lizmap Web Client on my
>> PC (and
>> then on a virtual server) mounting Ubuntu 16.04.
>> I cannot perform a working installation using Lizmap guide (found
>> both on
>> http://docs.3liz.com/it/admin_guide/installation/server_configuration.html
>> <http://docs.3liz.com/it/admin_guide/installation/server_configuration.html>
>> and
>> https://github.com/3liz/lizmap-documentation/blob/master/source/install/linux.srt
>> <https://github.com/3liz/lizmap-documentation/blob/master/source/install/linux.srt>
>> I can't install php5 (on Ubuntu 16.04 seems to be installed php7
>> by default)
>> I can't get an answer a GetCapabilities request from here:
>> http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> <http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
>> I can't see nothing from http://localhost/lm/
>> <http://localhost/lm/> test
>> page
>> I'd like to install new Lizmap 3 but it could be a succes if I
>> can configure
>> version 2 now!
>> Please support me step by step!
>> Thanks in advance
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Installing-map-server-Lizmap-on-Ubuntu-16-04-tp5271440.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> IEEE Member
> IEEE UACh Student Branch Counselor
IEEE Member
IEEE Student Branch Counselor - Universidad Austral de Chile
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160621/e12a89b0/attachment.html>
