[Qgis-user] QGIS Shapefile Structure (?)
Matthias Kuhn
matthias at opengis.ch
Wed Jun 22 02:19:57 PDT 2016
Hi Spring,
Which version of QGIS are you using?
On 06/22/2016 11:15 AM, Springfield Harrison wrote:
> Hello Alexandre,
> Ok, thank you. That is cumbersome but does work I guess.
> Does "Save As" clear out the deleted features or do they live on
> as ghosts?
> Thank you, cheers . . . . Spring
> At 22-06-2016 01:54 Wednesday, Alexandre Neto wrote:
>> Hello Spring,
>> This has to do with the way qgis (GDAL) handles the feature deletion.
>> Instead of totally removing them (which takes longer) it mark them as
>> deleted.
>> The (not very elegant) workaround here is to save the layer to a new
>> shapefile using save as...
>> Hope it helps
>> A qua, 22/06/2016, 09:39, Springfield Harrison <stellargps at gmail.com
>> <mailto:stellargps at gmail.com>> escreveu:
>> Hello All,
>> Â Â Â Â I have been opening QGIS shapefiles in Manifold GIS and
>> noticed that
>> they bear very little resemblance to the same file in QGIS, in some
>> cases. When I then saved that file in QGIS as a different file, and
>> opened it in Manifold GIS, all the features were present and arranged
>> as expected.
>> Â Â Â Â On another occasion, it looked like previously deleted
>> polygons were
>> visible when opened in Manifold GIS.
>> Â Â Â Â And, in another instance, when attempting in QGIS to create a
>> polygon, that failed. Instead, portions of old, deleted polygons
>> were reactivated instead! What is going on here? This does not look
>> like trustworthy behavior.
>> Â Â Â Â I tried using SpatiaLite files instead of shapefiles, but
>> there edit
>> and feature creation failed outright.
>> Â Â Â Â I believe this has been dealt with earlier; could someone
>> point me
>> to the discussion? I did a brief search but could not find the
>> relevant posts.
>> Â Â Â Â Â Â Â Â Thanks very much, Cheers . . . . . . . . Spring
>> Harrison
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com <http://gisunchained.wordpress.com/>
