[Qgis-user] QGIS Shapefile Structure (?)
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Jun 22 06:38:27 PDT 2016
I have no inside knowledge of this as I am not an the development team but I remember a good post on the subject explaining that Qgis did repack the shp file when closing the file with deleted features. Is this only done on a "save as"?
The problem may be cause by another GIS, like Manifold, as I remember that this problem could lead to a totally corrupt shape file like what we as seeing here.
Nicolas
On Jun 22, 2016 4:38 AM, "Alexandre Neto [via OSGeo.org] " <ml-node+s1560n5272780h41 at n6.nabble.com> wrote:
Hello Spring,
This has to do with the way qgis (GDAL) handles the feature deletion. Instead of totally removing them (which takes longer) it mark them as deleted.
The (not very elegant) workaround here is to save the layer to a new shapefile using save as...
Hope it helps
A qua, 22/06/2016, 09:39, Springfield Harrison < [hidden email] > escreveu: Hello All,
I have been opening QGIS shapefiles in Manifold GIS and noticed that
they bear very little resemblance to the same file in QGIS, in some
cases. When I then saved that file in QGIS as a different file, and
opened it in Manifold GIS, all the features were present and arranged
as expected.
On another occasion, it looked like previously deleted polygons were
visible when opened in Manifold GIS.
And, in another instance, when attempting in QGIS to create a
polygon, that failed. Instead, portions of old, deleted polygons
were reactivated instead! What is going on here? This does not look
like trustworthy behavior.
I tried using SpatiaLite files instead of shapefiles, but there edit
and feature creation failed outright.
I believe this has been dealt with earlier; could someone point me
to the discussion? I did a brief search but could not find the relevant posts.
Thanks very much, Cheers . . . . . . . . Spring Harrison
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user -- Alexandre Neto --------------------- @AlexNetoGeo http://sigsemgrilhetas.wordpress.com http://gisunchained.wordpress.com
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Can-not-build-python3-qt5-devel-rpm-in-fedora-21-tp5272729p5272780.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-not-build-python3-qt5-devel-rpm-in-fedora-21-tp5272729p5272851.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160622/eb23a6c6/attachment.html>
