[Qgis-user] QGis not running windows 7
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Jun 27 05:33:01 PDT 2016
Are you having other issues with Windows?  Is this a very old windows installation?  If so, you could try a reinstall of Windows if it's a few years old as a very last resort.
Before that, make sure you don't have an antivirus (or other anti-spyware) software running during the installation and when you start Qgis.  You could also try the other Qgis installation.
 So when QGIS starts, you see the splash screen and then nothing? No error messages?
Did you remove the hidden folders for all the users including admin?  Do you have an accent or spaces in your users name or user path? Apart from that, I am not sure.  If none of that works, I would repost and ask if there is a crash log being created.  That could help the developers figure it out.
Good luck
Nicolas
On Jun 27, 2016 7:01 AM, "defelix [via OSGeo.org]" <ml-node+s1560n5273521h12 at n6.nabble.com> wrote:
	Hi Nicolas,
thanks a lot for your reply, I uninstalled the current version of QGis, I removed all folders and registry entries, then I installed again using OSGEO,QGis 2.14.3, but unfortunately not success.
My OS is windows 7, 64bit.
What could I do now?
				Defelix
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273521.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273547.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160627/1767b853/attachment.html>
